iHass
Jan 24, 2019Initiate
Recognized Ethernet Connected Satellite Uses WIFI ID ORBI34
I have two RBS50's and one RBR50. All have the latest firmware. This particular satellite shows that it is connected via 5G even though it is connected via ethernet. It also shows the WIFI ID to be O...
- Jan 26, 2019
Finally factory reset the RBS50 satellite, connected it via Ethernet directly to the RBR50, and re-added to the system with the second RBS50 unplugged from power and it worked. This after trying to pair wirelessly several times and the iOS app not finding the RBS50. All is well now working with both RBS50 units showing as wired satellites. All are transmitting the same WiFi network and Orbi34 is gone.
Jan 26, 2019Guru - Experienced User
Any progress on this?
iHass wrote:
I have two RBS50's and one RBR50. All have the latest firmware. This particular satellite shows that it is connected via 5G even though it is connected via ethernet. It also shows the WIFI ID to be ORBI34 when the RBR50 transmits my assigned Wifi ID, as does the second RBS50. Anyone have any idea how to fix this? My second RBS50 shows connected via ethernet too, but transmits the wifi ID I assigned and is being transmitted by the RBR50. The RBR50 is set up as an access point directlty connected to a Peplink router.
iHass
Jan 26, 2019Initiate
- FURRYe38Jan 26, 2019Guru - Experienced User
Good to hear. Glad its working now and just a reset and re-add did the trick. Mark your thread as solve so others will know.
Enjoy. :smileywink:
