mr24shoe
Aug 18, 2020Aspirant
Recommendations for another satellite (RBK50, RBR50, RBS50)
I bought the RBK50 kit (containing 1 RBR50 and 1 RBS50) in mid-2018. I'd like to add another satellite, but am having some trouble finding a new RBS50. Can you recommend an alternative? I'd like ...
mr24shoe
Technically I don't, but I'd like to improve the network connectivity of devices on one side of our house...hardwiring to the satellite to take advantage of the stronger back channel vs. relying on their internal wifi antennas (proving to be not-great) was the thought...
Aug 18, 2020Guru - Experienced User
Yes you can wire up RBS:
- mr24shoeAug 19, 2020Aspirant
it's just under 2000, side-side split over 3 levels(2 levels per side, but 3 when looking at the whole house).
I'm seeing some RBS50's on ebay, so i'll probably go that route.
thanks!
- FURRYe38Aug 19, 2020Guru - Experienced User
For 2000sq ft 1 RBS should work well with the RBR.
Distance will be a factor here....
- MstrbigAug 19, 2020Master
mr24shoe wrote:it's just under 2000, side-side split over 3 levels(2 levels per side, but 3 when looking at the whole house).
thanks!
I was going to suggest Ebay, Offerup, Letgo and Facebook Marketplace for a used one.
