pete11727's avatar
pete11727
Recommended Orbi Mesh Network type
We have a three story home, with the Cable modem coming into the basement. Would you recomment going with a Daisy Chain or Star network. I am considering putting the Router on the main floof via exis...
  • tomschmidt's avatar
    tomschmidt
    Mar 19, 2020
    Extending the cable for the modem to the main floor would be a viable option. This is your choice.  The CAT5 cable is probably fine if your ISP speed is 100Mb/s or less, but cannot handle 1Gb/s.
