pete11727
Mar 19, 2020Aspirant
Recommended Orbi Mesh Network type
We have a three story home, with the Cable modem coming into the basement. Would you recomment going with a Daisy Chain or Star network. I am considering putting the Router on the main floof via exis...
- Mar 19, 2020
Extending the cable for the modem to the main floor would be a viable option. This is your choice. The CAT5 cable is probably fine if your ISP speed is 100Mb/s or less, but cannot handle 1Gb/s.
pete11727
Thanks Tom. The wiring is 18 year old Cat5, so it sounds like using the Gbyte cable from modem to router is the way to go. Only other option I can think of is coupling the incoming cable coax to a mainfloor coax port and moving both the modem and Orbi router. Do you think that woule be worth the extra effort?
Thanks again.
Pete
tomschmidt
Mar 19, 2020Virtuoso
