Haselmaier
Feb 16, 2022Guide
Recommended Orbi Solution For Isolated Networks
I'm struggling to figure out which Netgear solution(s) would solve my problem. I've been looking at Orbi primarily so I thought I'd post the question here. Overall context: Have cable service t...
Haselmaier
Feb 16, 2022Guide
Thanks very much. I appreciate it.
Hardwire to satelites is not an option unfortunately.
Currently only have one device that is WiFi 6 capable. I'm hoping I could get more throughput to the laptops than the current 250Mbps we're getting on AC1750.
I was actually considering the Orbi Pro WiFi 5 Tri-Band - the SRK60 (AC3000). It's available for (what seems like) a steal on Amazon: $150. Given that price point it leaves room in the budget (or makes it easier) to get a separate firewall.
Feb 16, 2022Guru - Experienced User
that's a pretty good price for that setup.
You probably won't see much speed difference as the fronthaul is still 866mbps (5ghz) and 400mbps (2.4gh) on link speed.
Hardwired into it you'll see a difference.
And I've never used that version so can't attest to the vlan/multiple ssid aspect of it.
but its still a good price on that setup.
