hibbotte
Jul 06, 2020Tutor
Recommended Unmanaged Switch (Non-Green) for use with Orbi
I'm looking for recommendations on an Unmanaged Switch (Non-Green) for use with the Orbi RBK40 system. I ordered a TP-Link 24 port unmanaged switch and it didn't play well with my Orbi. I believe it was due to it being a green unit.
I prefer HP ProCurve 1400/1800 series switches.
Some have said that NGs GS105/108 works with Orbi even though they seem to have some Green Ethernet features.
I've tried D-Links DGS105/108 and they have worked for me as well. Also D-Links DGS-1100 is a managed switch that doesn't have green ethernet and you can disable it's IGMP protocols on it...works with Orbi.
- hibbotteTutor
Thanks so much for the quick response!
Cheers!
Good Luck.
- hibbotteTutor
https://www.amazon.com/gp/product/B004M0LFSA/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
I ordered the D-Links DGS-1100, but now I'm seeing it listed as having D-Link Green. I guess I should cancel the order, ha.
I believe that feature can be disabled. :smileywink:
