RobertRosal
Jan 22, 2019Virtuoso
Reconnecting Satellite
So I removed one of my Satellites from the management console which was connected via wireless and moved it to another location. At this new location there is a lan cable which I will now be using. ...
- Jan 24, 2019
What is the Mfr and model# of the ethernet switch in the configuration?
Good to hear. Mark your thread solved so others will know. Glad to be of help.
RobertRosal wrote:
So it did some doing but I juggled everything around and was able to connect the satellites directly to the router. I am happy to say everything is working great and working as it should be now.
Showing Backhaul as good and both satellites showing connected via wire. Also the app on the phone and the console on my laptop both read the same now!
I am one happy camper!
Thanks again Furry!
RobertRosal
Jan 24, 2019Virtuoso
Thanks again Furry!
Jan 24, 2019Guru - Experienced User
Thanks again Furry!
