jasperx's avatar
jasperx
Tutor
Jun 21, 2019
Recovering from a lightening strike RBK 53 -satellites in AP mode ATT modem wifi left on
With the videos and advice on these pages I had things working great. Configuration is : ATT modem/router > Orbi Base in AP mode > Gigabit switch > Orbi satellites.  I had turned off the wifi networ...
  • FURRYe38's avatar
    Thats the recommended method to do this in, however it's not set in stone. You can disable the wifi on the ISP modem and power cycle the Orbi system and leave the other devices on and after the Orbi is online, those devices should reconnect automatically.
