KazB
Dec 03, 2019Initiate
Red dot on router in network map
I have set up my new orbi and it appears to be working. However on the Network App in the app it has a red dot next to the Router, both Satelittes have a green dot. On the home page of the app it say...
CrimpOn
Dec 03, 2019Guru - Experienced User
Is the WAN (yellow) port on the Orbi connected to the internet modem, or one of the other ports?
KazB
Dec 05, 2019Initiate
Yes it is yellow port on the orbi to a yellow port on the modem
- FURRYe38Dec 06, 2019Guru - Experienced User
- Daniellen1Mar 05, 2020AspirantDoes the ref dot on the Satellite mean it's connected or not, its a simple question? The app has shown red since i owned this turd and would like to know its actually connected to the orbi that is hard wired connected to the wall/internet upstairs. I have low bars right next to it which gives me the impression it's not actually working.
- CrimpOnMar 05, 2020Guru - Experienced User
Daniellen1 wrote:
Does the ref dot on the Satellite mean it's connected or not, its a simple question?This question appears to be separate from the post that started this discussion. As far as I know, "Red Dot" on a satellite means "not connected". I am not as comfortable with the Orbi "app" as with the Orbi web interface. Open any web browser to http://orbilogin.net, log in with the Orbi admin credentials ("admin" and the Orbi admin password), and open the "Attached Devices" page. Satellites appear at the top.
