Swenson0110
Nov 19, 2021Follower
Red Light vs Amber Light On Satellite During Attempt To Reset
CONFIG: (1) RBR50 With (2) RBS50 FW: 2.7.3.22 I reset all of the mesh devices in my home and started from the groud - up. The router and one of the two satellights worked fine. The other s...
Nov 19, 2021Guru - Experienced User
How long are you pressing the reset button for on the RBS? 15 seconds then release should do it.
