Rune777
Dec 21, 2021Aspirant
Red power flashes ones
Hi guys My CBR40 just abrouptly stopped working. When i unplugg it or turn the power on off, the power LED on the front just flashes red one time then nothing. I tried to do a factory reset but s...
Rune777
Dec 22, 2021Aspirant
I tried to do a factory reset, and re install everything. For some reason the green LED light never comes and it cant connected to the service provider, i get a local network working but i cant connect to the internet... I know the cable connection is good as i have tried an old modem and had spectrum swap mac address... Bummer that the product only lasts two years and then breaks...
- FURRYe38Dec 22, 2021Guru - Experienced User
Can you try a different power supply with same spec as original?
Can you access the CBRs web at all?
- Rune777Dec 22, 2021Aspirant
I have tried that and it doesnt help. The power works and i can connect locally to it, it but it fails to connect to the cable service provider. The LED light on the front dont glow, but the rings on top does. so when im resetting it up the network light never comes on
I just updated it to it to the latest firmware and still no luck...
Please post a copy and paste of the modems connection status page if you can get to that section in the CBRs web page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.htmlSo try this, Power OFF the CBR.
Disconnect the CBR from the coax line. Power ON the CBR and see if you can still access the CBRs web page?MIght try a full on ERASE from the Advanced tab/Admin/Backup Settings section. Does the front LED blink after the CBR resets with out the Coax cable connected?
