thombe
Feb 14, 2021Apprentice
RED Power Led Orbi RBS40v
Hi all I had a working RBS40V however i moved it and now the power led just shows RED (the little light at the back). Normally ofc this would be a greed light to show power to the device. ...
Feb 14, 2021Guru - Experienced User
sounds like you might have a corrupt firmware or boot up issue.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
thombe
Feb 15, 2021Apprentice
Oh you legend... i'll give those a go.
Thanks, i'll report when i can
Ben
- plemansFeb 15, 2021Guru - Experienced User
tftp can sometimes take a few tries because its sensitive to timing. MIght be worth trying a few times.
If you can't recover it using tftp/nmrpflash, you might indeed have a brick.
