thombe
Feb 14, 2021Apprentice
RED Power Led Orbi RBS40v
Hi all I had a working RBS40V however i moved it and now the power led just shows RED (the little light at the back). Normally ofc this would be a greed light to show power to the device. ...
thombe
Feb 15, 2021Apprentice
Hi, so the first method didn't work, using a static ip address on ethernet, as the device doesn't respond to 168.1.1., so i guess i need to try the other tool
however , idiot here.. not absoutely sure on the method. downloaded the zip, (and installed npcap)
but unclear of method to start nmrpflash as its not a cmd or bat or similar.
how do i "run" it ?
i'm on windows 10 but also have ubuntu dual boot so can do it within linux if its easier
i'm sure you're eyes are rolling at such stupidity but a little idiots guide to start would be greatly appreciated.
thanks again
ben
thombe
ignore my windows questions, i used ubuntu in the end, after compiling
however i think it is dead as i get Advertising NMRP server on enp8s0 (my ethernet)...
then it finally ends.. No response after 60 seconds. Bailing out.
so do i assume then this is a brick ?
