thombe
Feb 14, 2021Apprentice
RED Power Led Orbi RBS40v
Hi all I had a working RBS40V however i moved it and now the power led just shows RED (the little light at the back). Normally ofc this would be a greed light to show power to the device. ...
thombe
Feb 15, 2021Apprentice
Oh you legend... i'll give those a go.
Thanks, i'll report when i can
Ben
Feb 15, 2021Guru - Experienced User
tftp can sometimes take a few tries because its sensitive to timing. MIght be worth trying a few times.
If you can't recover it using tftp/nmrpflash, you might indeed have a brick.
