DZone
Jul 04, 2018Aspirant
redirecting Google search page
I have an Orbi RDR20 at firmware v2.1.4.16 which is apparently redirecting www.google.com to Japan’s www.google.co.jp. This happened after hitting several Japan websites while scheduling a trip. Thi...
Jul 04, 2018Guru - Experienced User
Factory reset should clear any possible caches on the router. Use the ERASE feature in the UI or press the reset button until the top led turn on Amber. Then let go. Wait for the top led to pulse WHITE slowly then set up from scratch.
Try inputting your ISPs DNS using static DNS entries on the router.
Besure to clear any bowser caches as well.
Whats the mfr and model# of the ISP modem the orbi is connected too?
DZone
Thanx for responding.
Tried the factory reset several times according to instructions — no joy.
Also, tried static DNS addresses using Orbi dashboard — no joy.
Also tried ipconfig /flushdns and /release,/renew.
tracert shows consistent hops to a Calif Google site, then destination 1st octet mostly 172 but occasionally 216. Regardless, the end screen always is Google Japan.
Modem is Ubee DDM3521(?) from ISP, Spectrum.
Seems strange that a router would cause such a selective problem. ISP seems clear as simply swapping the router resolves the issue. Could culprit be tables at Google itself?
- FURRYe38Jul 05, 2018Guru - Experienced User
- DZoneJul 06, 2018AspirantThanks for the suggest but again, no joy. Tried Quad9 9.9.9.9 (as tribute to 36yr career w/Big Blue’s big iron). But rejected by Big Bro’ ISP (Spectrum).
W/out evidence of Orbi intelligently managing an internal routing table, it seems
more likely that Google is using an algorithm
which flagged my Orbi as belonging to a Japanese national — especially, analyzing website history and using an “arp”-like command to id my router. In these days of customer data mining and profiling, I wouldn’t be surprised.
