bearyoung
Oct 25, 2019Aspirant
region change on RBK23
bought a new Orbi RBK23 with RBR20 and RBS20, will move to Germany, can I change the region to Europe? maybe via telnet? found a method used on RBK53, but not sure if it works also on RBK23. did some one test this? thanks
Sort By
Once you log in to the RBRs web page, you should see a drop down menu that says AUTO under the log out button. Select this drop down and you can select the country available in the list.
bearyoung wrote:bought a new Orbi RBK23 with RBR20 and RBS20, will move to Germany, can I change the region to Europe? maybe via telnet? found a method used on RBK53, but not sure if it works also on RBK23. did some one test this? thanks
- bearyoungAspirantIt is grayed up in the Menu, how can I deal with it?
What browser are you using? Try a different browser?
I looked at mine in Opera. It's selectable.
Might need a factory reset once you get into country and then setup from there.
- robidogAspirant
What you descibe is the GUI language, not the WiFi regional setting, lol.
