bha19
Apr 08, 2023Aspirant
Registering old router
I bought a used ORBI and am trying to register it on the portal. I know it is out of warranty, but since it is registered to the previous owner is there a way to still register the router on the 198....
- Apr 09, 2023
All is well now, I just did a reset on the back of the router.
bha19
Apr 09, 2023Aspirant
When I go to 192.168.1.1 it asks for a username and password. That is what I am referring to and need access to. I do not need support just access. I tried the default login and that did not work.
bha19
- FURRYe38Apr 10, 2023Guru - Experienced User
