jpthibault
Jul 03, 2020Aspirant
Regrets, I have a few: RBR50 and ORBI21
I regret buying this pair beause an extra satellite (ORBI21) isn't avalable for purchase anywhere in Canada. One of the reasons why I bought the pair was its claimed ability to easily expand. It's ...
- Jul 03, 2020
jpthibault wrote:I appreciate your quick help, but I'm not sure that you understand my issue: I need a second satellite, that operates as the same speed as my exsiting two (RBS50 and RBR50) and a single RBS50 is not available in the Canadian market for sale.
You are SO right. Orbi owners are scouring the used market for additional satellites. (eBay, for example). I keep looking for another RBS50 and the asking prices are unbelievable. I have seen no comment from Netgear. The speculation seems to be (a) Netgear has shifted focus to the new WiFi6 product, and (b) this ghastly pandemic has disrupted the supply chain.
It is not pleasant situation. There are a couple of possibilities:
- Any of the original Orbi satellites will fully integrate with the Orbi RBR50 router. Depending on the internet connection speed, end users may notice no difference at all in performance. RBS20, RBS40, RBW30 all work. The RBS50Y (outdoor) model works, but the cost is prohibitive.
- Depending on your need, you can expand coverage with any brand of "WiFi extender".
For example, if the problem to be solved is some device that is slightly too far away, and never moves (such garage door opener, irrigation controller, security camera, etc.) then you can extend WiFi to just that device using a product from almost any vendor. TP-Liink's N300 2.4G extender, for example, retails for $20US.
Not what you wanted to hear. Sorry.
Jul 03, 2020Guru - Experienced User
What is Orbi21? This isn't a model rather a SSID name possibly. Do you mean a RBS20?
jpthibault
Aw yes, you are correct. the model is RBS50.
- jpthibaultJul 03, 2020Aspirant
F/W V2.5.1.16
- FURRYe38Jul 03, 2020Guru - Experienced User
The RBS50 and RBR50 will be a good match.
Is the Orbi system operating in Router or AP mode?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
