jpthibault
Jul 03, 2020Aspirant
Regrets, I have a few: RBR50 and ORBI21
I regret buying this pair beause an extra satellite (ORBI21) isn't avalable for purchase anywhere in Canada. One of the reasons why I bought the pair was its claimed ability to easily expand. It's ...
- Jul 03, 2020
jpthibault wrote:I appreciate your quick help, but I'm not sure that you understand my issue: I need a second satellite, that operates as the same speed as my exsiting two (RBS50 and RBR50) and a single RBS50 is not available in the Canadian market for sale.
You are SO right. Orbi owners are scouring the used market for additional satellites. (eBay, for example). I keep looking for another RBS50 and the asking prices are unbelievable. I have seen no comment from Netgear. The speculation seems to be (a) Netgear has shifted focus to the new WiFi6 product, and (b) this ghastly pandemic has disrupted the supply chain.
It is not pleasant situation. There are a couple of possibilities:
- Any of the original Orbi satellites will fully integrate with the Orbi RBR50 router. Depending on the internet connection speed, end users may notice no difference at all in performance. RBS20, RBS40, RBW30 all work. The RBS50Y (outdoor) model works, but the cost is prohibitive.
- Depending on your need, you can expand coverage with any brand of "WiFi extender".
For example, if the problem to be solved is some device that is slightly too far away, and never moves (such garage door opener, irrigation controller, security camera, etc.) then you can extend WiFi to just that device using a product from almost any vendor. TP-Liink's N300 2.4G extender, for example, retails for $20US.
Not what you wanted to hear. Sorry.
jpthibault
CrimpOn
Jul 03, 2020Guru - Experienced User
