rksorbi
Nov 16, 2020Aspirant
Regretting Orbi install - please help RBK50
Hello All, I had bought an Orbi some time back and finally over the weekend i installed it. The installation process was simple - but now i am really regretting it. I kept the same wifi name and ...
Nov 16, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
rksorbi
Nov 19, 2020Aspirant
Thank you FURRYe38
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? - I have got SKY ( UK broadband provider), it's a Sky Q router.
Is the Orbi system operating in Router or AP mode? - I never got an option to choose one, i used the Orbi app on my iphone to install it - i believe it's now the default router. Should that be changed and is it possible to change that please?
What is the size of your home? Sq Ft? 800 sq ft
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. - This is a good point right now that's more like 15ft, i have kept the satellite around the centre of our home, i can move it to the edge and see if that helps.
Regarding the other suggestions - i actually tried that by logging in to http://orbilogin.com and http://orbilogin.net I was able to log into both sites once make some of these changes and apply and after that it no longer opens. I keep getting that error page saying page is not available - i have tried clearning cookies etc. deleting history and using another browser but no luck - it almost feels like NG doesn't want me to use and make such changes and rely only the Orbi App which has no ability to change any configurations. If there is away to solve this to reach the admin page that would be much appreciated.
- rksorbiNov 19, 2020Aspirant
Apologies - just to add when i try to connect to https://orbilogin.com this is the error i get ( i am using my mac laptop using wifi via Orbi)
Connect to the Orbi WiFi Network Looks like you’re not connected to your Orbi’s WiFi network. Don’t worry, it happens to the best of us. Try the following steps to get connected:
- FURRYe38Jan 15, 2021Guru - Experienced User
Any progress on this?
rksorbi wrote:Apologies - just to add when i try to connect to https://orbilogin.com this is the error i get ( i am using my mac laptop using wifi via Orbi)
- vajimJan 15, 2021Master
- FURRYe38Nov 20, 2020Guru - Experienced User
rksorbi wrote:What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? - I have got SKY ( UK broadband provider), it's a Sky Q router.
What mode is the modem working in router or bridge? if router, his would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopIs the Orbi system operating in Router or AP mode? - I never got an option to choose one, i used the Orbi app on my iphone to install it - i believe it's now the default router. Should that be changed and is it possible to change that please?
You'll get this feature when using a PC and web browser connected to 192.168.1.1 or orbilogin.com
For the size of home, the RBS may not be needed.
