rudy74
Sep 26, 2019Aspirant
Reinstall orbi rbk53 after provider swap?
I am thinking of choosing another internet provider. Do i have to reinstall my orbi setup too if i do that? Any help would be appreciated. Thx
Sep 26, 2019Guru - Experienced User
Power OFF The RBR first. Connect up to new modem. Power On the modem first and let it sync. Power ON the RBR. Hopefully you should see a BLUE ring LED at the top then go out. Means its working.
Thx
- rudy74Sep 29, 2019Aspirant
thank you for your fast reply!
