screwgauge
Dec 01, 2022Aspirant
Reliable way to put an Orbi Satellite (RBS50) in TFTP Server mode where I can push firmware
Hello, Can someone please describe reliable and repeatable steps to put an Orbi Satellite (RBS50) into a mode where I can tftp put the firmware image to it. I can get it to a state where it has...
Dec 01, 2022Guru - Experienced User
I've had better luck using nmrpflash when flashing satellites. I'd give that a shot
screwgauge
No luck. nmrpflash also relies on TFTP but its unable to send the firmware to the device. I see this in tcpdump
00:13:07.177431 IP 192.168.2.2.62444 > 192.168.2.1.tftp: 30 WRQ "firmwareoctetblksize1456" [|tftp]
00:13:09.178786 IP 192.168.2.2.62444 > 192.168.2.1.tftp: 30 WRQ "firmwareoctetblksize1456" [|tftp]
00:13:11.180535 IP 192.168.2.2.62444 > 192.168.2.1.tftp: 30 WRQ "firmwareoctetblksize1456" [|tftp]
00:13:13.185118 IP 192.168.2.2.62444 > 192.168.2.1.tftp: 30 WRQ "firmwareoctetblksize1456" [|tftp]
00:13:15.187482 IP 192.168.2.2.62444 > 192.168.2.1.tftp: 30 WRQ "firmwareoctetblksize1456" [|tftp]
00:13:17.189839 IP 192.168.2.2.62444 > 192.168.2.1.tftp: 30 WRQ "firmwareoctetblksize1456" [|tftp]
I need a brute force way to get the Orbi Satellite to get into TFTP server mode. Or is there an alternate way where it can act as a TFTP client and download firmware?
- CrimpOnDec 01, 2022Guru - Experienced User
My limited experience with TFTP was frustrating because "timing is everything". I once attempted to load firmware on an Orbi (I believe a router) with TFTP and failed five times in a row*. Was taking aim at the trash can and thought, "what do I have to lose by trying a few more times?" Attempt six worked!
My conclusion is that every time an Orbi powers up, there is a brief window of time when it looks for a TFTP connection. Too soon and the Orbi isn't ready yet. Too late, and it has already moved on to loading the previous firmware image.
So, I do not believe there is anything that needs to be done. I think Orbi's go through this process every time they power on.
*part of this was me being spastic. The TFTP software I was using seemed to forget which file was to be transferred so when I went to click on Send, there was no file and by the time I browsed to the file, the window had closed.
p.s. Thanks for the hint to capture the network traffic (I use Wireshark) during a TFTP session to watch what happens.
- FURRYe38Dec 01, 2022Guru - Experienced User
I wanna say that someone post that nmrpflash helps with the timing or help the user in getting to the point in where the user doesn't have to figure that out...I haven't used it yet. Might be something to check out though.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=R9DLrLQrpaw
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a Windows 7 PC and the TFTP worked.
Mac TFTP: https://www.petenetlive.com/KB/Article/0001247
00:13:07.177431 IP 192.168.2.2.62444 > 192.168.2.1.tftp: 30 WRQ "firmwareoctetblksize1456" [|tftp]Maybe I'm reading this incorrectly. Flashing firmware is sort of a chore because the device and TFTP machine have to be disconnected from everything else, the computer has to be changed to a static IP, etc. Afterwards, it all has to be put back the way it was before.
If the satellite is at 192.168.1.250 (this is before it loads the firmware image and changes to the IP address that it has been assigned, usually using DHCP to learn what that IP address is), what is the point of sending packets from 192.168.2.2 to 192.168.2.1 ?
- plemansDec 01, 2022Guru - Experienced User
was wondering about the 2.1 address as well. Doesn't really follow the guide
This article claims that U-Boot used by Netgear routers waits for 3 seconds in case an NMRP firmware load might happen.
p.s. I had not realized that NMRPFlash is in active development. The latest version was released only 16 days ago!
p.p.s. It is also not clear (to me) whether NMRP protocol encapsulates TFTP or is in addition to TFTP.
- screwgaugeDec 01, 2022Aspirant
When trying to tftp directly (not via nmrpflash), I had assigned a static IP of 192.168.1.1 to my Macbook (ethernet interface). Then I keep pinging 192.168.1.250 and at one point there is consistent ping but I cannot tftp to it since nothing on the Satellite is listening on port 69.
When you use nmrpflash it wants to assign a separate IP to the ethernet interface (on the Mac) and also assign one to the target (Satellite).
For this it aliases an IP (in my case 191.168.2.2 to the same Ethernet interface on the Macbook) and tries to offer 192.168.2.1 to the Satellite when it comes up. If you run nmrpflash without the -a and -A options, it does the same on a 10.xx subnet.- CrimpOnDec 01, 2022Guru - Experienced User
(If there were merit badges for network expertise, I would not have one yet....)
I think the point is that during that three seconds, the satellite has not yet booted the firmware, and thus cannot respond to ICMP. The only firmware that is running is U-Boot and it waits only three seconds for a TFTP connection. After that, it is no longer 192.168.1.250. And, if the firmware that gets loaded is corrupted, it might not be anything at all.
