bsholbrook
Jan 25, 2017Apprentice
Remote Desktop connection - jump desktop software
Unable to get jump desktop software to make a Remote Desktop connection through orbi into home pc. Works fine through LAN, but not wan. Anyone have experience or info? Essentially and rdp or vnc type connection
- st_shawMaster
You need to setup port forwarding for TCP port 3389 and direct it to the LAN IP of your pc. This exposes your pc to Internet attacks, so you are better off coming in through a VPN, or at least forwarding a random high port to port 3389 on your pc.
- bsholbrookApprentice
Jump has a front end handshake ahead of any vnc or rdp communications, it's not a native connections. While the port forward mayhelp I don't think this resolves the frontend issue. I've also never setup port forwarding on prior apple or asus routers that I've used.
- itGeeksApprentice
Have you ever tried TeamViewer? It woud be safer then opening a port for RDP. Give it a try its free for home use
