roughneck1058
Aug 03, 2018Aspirant
Remote Desktop Connection Drops
Hi all,
So here's my situation, before moving, I was using a standard modem router from my ISP (Spectrum) and I could RDP from my home desktop to my work laptop (so I can have a normal size keyboar...
Aug 07, 2018Guru - Experienced User
FW as in Firmware...
You can get 40Mhz coexistence by unchecking 20/40Mhz Coexistence.
Can you wire up both PC and laptop directly to the router and see if RDP works using LAN connections.
