srdjedit
Sep 06, 2019Aspirant
Remote Desktop on a Mac
I can connect my laptop to my iMac at home via Remote Desktop. But when I'm at work it will not connect. It says can't connect check firewall etc... I don't have a firewall at home. As far as firmwa...
srdjedit
Thanks for the reply! I have limited knowledge about VPNs, I know what they do but how would a VPN help?
Thanks
Scott
ekhalil
Sep 07, 2019Master
VPN is a secure tunnel between your computer and the internet. You can use VPN to eastablish a tunnel between your computer at work and Orbi.
By doing so you will be seen by Orbi as if you're sitting at home with a private IP address, so you will have access to the Orbi network exactly as if you have wifi connection to Orbi.
To configure VPN, you need first to configure DDNS in Orbi then configure VPN. You can find both settings under the >> ADVANCED >> Advanced >> in the web GUI.
I hope that helps.
