vintegra90
Aug 21, 2019Aspirant
Remote management - Orbi RBR50 AC3000
I used to be able to use remote management on my cell phone, no problem. I don't know what changed (I have the same phone), but it no longer works. I didn't do a factory reset of my router as far a...
- Sep 07, 2019
Thanks for the replies. Just wanted to update the case for closure and to say the fault seems to be my own. Somehow I created two accounts with my different email addresses and when trying to login with my new email, it would let me access my router settings through wifi, but block me from remote connecting. Netgear pointed out my old email address and I confirmed it with them so now I can connect remotely with it.
Aug 21, 2019Guru - Experienced User
Is Remote Management enabed already on the RBRs web page?
vintegra90
Firmware: v2.3.5.30
App version: 2.3.7.622
Modem: Netgear CM700
Remote management is enabled on website, but error appears when trying on app
- FURRYe38Aug 21, 2019Guru - Experienced User
I would post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
- vintegra90Sep 07, 2019Aspirant
