vuskie
Jul 13, 2018Tutor
Remote Management via Orbi App
Hello All, I am new to this community and have recently bought an Orbi RBK43. I searched the threads for related issues but couldn't find anything.
My problem is that I am using the Orbi I...
- Jul 13, 2018
I spent so much time with support for this very issue and the way I resolved it was to :
1. open the app while on wifi
2. Go into settings from the mobile app and DISABLE remote management
3. Toggle remote management back on
4. disconnect your phone from wifi and try to see it again, should show up
futureAlec
Jul 13, 2018Guide
CowBoy1
Jul 17, 2018Aspirant
Sorry, on your step two
"2. Go into settings from the mobile app and DISABLE remote management"
how to get into setting from Orbi App (I'm Android phone).
Thanks,
- futureAlecJul 18, 2018Guide
I apologize, I am on an iphone. Assuming it is similar I do this...
While on wifi :
1. Open the app
2. Tap The Home Icon (no text just a little picture of a house, on iphone this is in the upper left hand corner)
3. Tap settings (Little gear icon, next to the word 'Settings')
4. Tap 'Remote Management'
5. Toggle Remote Management to off.
6. Toggle Remote Management to on.
That should do the trick, Hope this helps!
