vuskie
Jul 13, 2018Tutor
Remote Management via Orbi App
Hello All, I am new to this community and have recently bought an Orbi RBK43. I searched the threads for related issues but couldn't find anything.
My problem is that I am using the Orbi I...
- Jul 13, 2018
I spent so much time with support for this very issue and the way I resolved it was to :
1. open the app while on wifi
2. Go into settings from the mobile app and DISABLE remote management
3. Toggle remote management back on
4. disconnect your phone from wifi and try to see it again, should show up
futureAlec
Jul 13, 2018Guide
EvilDaifu
Jul 30, 2018Initiate
Yep this works! Orbi cloud settings look like they need a kick to pick up IP addresses.
