Horbeme
Jan 03, 2018Aspirant
Remote Management
i have a RBR40 wth satelite setup, i configured my orbi router with ssid as well as a guest ssid. i diabled the dhcp on the orbi router so my isp supplied router can assign with a network i specified...
DarrenM
Jan 08, 2018Sr. NETGEAR Moderator
You should be able to use the internal Ip address that your router is assigning the orbi unit.
DarrenM
scyu6058
Jan 08, 2018Tutor
If your router has a static IP assigned by your ISP, you do not need the DDNS setup. You should see the required access address in the Remore Management page. Note that you should use "https", not "http". Be sure to add the port number after the address.
If you have setup the DDNS in the DDNS page, the address listed should reflect this automatically.
