Fred_m
Oct 28, 2018Tutor
Remote Management
Hello When I try to activate remote management I get message that this device is registered to another account. This device is the correct device in my account and I bought this new. Recieved an emai...
Blanca_O
Oct 28, 2018NETGEAR Employee Retired
Fred_m
Oct 28, 2018Tutor
Hello Blanca’s
Just replied to you questions
- Blanca_OOct 28, 2018NETGEAR Employee Retired
Hi Fred_m
Thank you for responding. System shows that the device is indeed registered to your profile. Please try to uninstall and re-install the app. If still not working, kindly factory reset the unit and try again.
Blanca
Community Team- Fred_mOct 28, 2018TutorI have already done removed and reinstalled the app
Have not done a reset. Will do so and see
So I reset the router only or the satellite too - Blanca_OOct 28, 2018NETGEAR Employee Retired
Hi Fred_m
Kindly reset first the satellite then the router. Please let me know how it goes.
Blanca
Community Team- Fred_mOct 28, 2018TutorIt Worked. Finally
Thank you
