colehme
Jan 18, 2020Aspirant
Remote management
When I try to enable remote managment I get the message, "this NETGEAR device is already registered with another account." To the best of my knowledge I only have one NETGEAR account.
colehme
Jan 26, 2020Aspirant
THANKS FOR YOUR REPSONSE. IT WAS HELPFUL. THE FOLKS AT NETGEAR SUCCESSFULLY PUT ALL OF MY PRODUCTS UNDER ONE E-MAIL ADDRESS. I AM STILL UNABLE TO ENABLE REMOTE MANAGMENT. I THINK IT'S STILL THE SAME PROBLEM, MY ORBI APP WAS SET UP UNDER A DIFFERENT E-MAIL THAN WHERE MY EQUIPMENT IS REGISTERED. HOW CAN I SET UP THE ORBI APP WITH THE CORRECT E-MAIL ADDRESS? I CAN LOG OUT BUT I CAN'T RESET. DO I START ALL OVER AS IF I'M SETTING UP A NEW ACCOUNT? IS THERE ANOTHER WAY TO CONNECT THE APP TO THE RIGHT EQUIPMENT?
Jan 26, 2020Guru - Experienced User
Please use the caps lock and ensure it's not enabled.
Thank you.
Please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
colehme wrote:THANKS FOR YOUR REPSONSE. IT WAS HELPFUL. THE FOLKS AT NETGEAR SUCCESSFULLY PUT ALL OF MY PRODUCTS UNDER ONE E-MAIL ADDRESS. I AM STILL UNABLE TO ENABLE REMOTE MANAGMENT. I THINK IT'S STILL THE SAME PROBLEM, MY ORBI APP WAS SET UP UNDER A DIFFERENT E-MAIL THAN WHERE MY EQUIPMENT IS REGISTERED. HOW CAN I SET UP THE ORBI APP WITH THE CORRECT E-MAIL ADDRESS? I CAN LOG OUT BUT I CAN'T RESET. DO I START ALL OVER AS IF I'M SETTING UP A NEW ACCOUNT? IS THERE ANOTHER WAY TO CONNECT THE APP TO THE RIGHT EQUIPMENT?
