JoeHag
Nov 23, 2020Tutor
remote reboot of orbi systems
i have current versions of code on all devices. I want to reboot the router AND ALL THE SATELLITES remotely (with software). When I connect with a browser - I see no way to reboot anything. If there...
Nov 23, 2020Guru - Experienced User
CrimpOn
Nov 24, 2020Guru - Experienced User
Success.
I repurposed one of my TP-Link HS-105 smart plugs. Configured it with the Orbi guest WiFi and set it to turn OFF at 11:59am and turn ON at 12:02pm. Plugged in a fan. About 11:55 I disabled the Orbi guest access. LED on the smart plug went from Blue to Orange (no WiFi) but the fan kept running. Exactly at 11:59, the fan stopped. At 12:02, the fan came back on. That article was correct. The "schedule' is stored in the plug itself and does not need WiFi or internet connection to work.
Just personally, I see no advantage to power cycling my entire house WiFi. This experiment as a "proof of concept" was successful. I have no idea if other brands of smart plugs operate in the same manner, but it would be easy enough to check.
