JoeHag
Nov 23, 2020Tutor
remote reboot of orbi systems
i have current versions of code on all devices. I want to reboot the router AND ALL THE SATELLITES remotely (with software). When I connect with a browser - I see no way to reboot anything. If there...
CrimpOn
Nov 23, 2020Guru - Experienced User
JoeHag wrote:i have current versions of code on all devices.
I want to reboot the router AND ALL THE SATELLITES remotely (with software). When I connect with a browser - I see no way to reboot anything. If there is, please point me to it. I used the ANDROID app, under the HOME icon and it appears to only reboot the router itself (Orbi base). How do I remotely reboot the satellites (one at a time or all together). The backhaul RBR50 is wired and the RBS40v is wireless.
Also, someone posted a desire to have a scheduled reboot in the software, I would also support that as an option.
thanks,
What you want can be done, but it is not simple, quick or convenient. Orbi units support telnet access (the original Orbi's at least). So, you could do this:
- Turn on OpenVPN (which is often a challenge) and get it to work reliably with your remote device (laptop, tablet, etc.)
- When you want to reboot the Orbi units:
- Connect to the Orbi using OpenVPN
- Open a telnet app
- Connect to one of the satellites by IP address
- Log in using the admin credentials ("admin" and password)
- Type the command "reboot"
- Drop the telnet connection
- Connect to another satellite & repeat
- Finally, connect to the Orbi router & repeat (which, of course, will break the OpenVPN connection)
My guess is that this is not a solution very many people would embrace.
The second question: "scheduled reboot" can be handled with hardware, i.e. smart plugs.
This article on the web explains how smart plugs can function without internet access:
https://livinghightech.com/smart-plugs-internet-down/
I was drawn to this paragraph:
Schedules Created in Device Apps
Schedules created for name brand devices, like Hue WeMo and Kasa will continue to work if the internet goes down. This is because the schedule gets saved to the device (or hub for hue). If the internet is down for too long the devices may lose their time and then the schedule will stop working.
With (for example) three KASA smart plugs, a schedule might be:
On Sunday morning at 1:00am, turn off all of the plugs
On Sunday morning at 1:01am, turn on the router plug
(wait for the router to come up)
On Sunday morning at 1:05am, turn on the satellite plugs
I would start with one KASA plug on one satellite to verify that it actually works. i.e. if the Smart Plug is connected to the satellite WiFi, when the satellite is shut off, that WiFi connection should go down. Honestly, I don't know if the Smart Plug will search out a different Orbi or if it will wait for the satellite to reappear.
In my case, this is sort of academic, since my Orbi stays powered up (on UPS) until there is a power outage that lasts longer than 30 minutes. (Several times for over 4 months.)
JoeHag
Nov 25, 2020Tutor
thanks - the telnet sounds promising... except I get this...
telnet 192.168.1.2
Connecting To 192.168.1.2...Could not open connection to the host, on port 23: Connect failed
are we not using 23? Any ideas?
thanks!
JOE
- FURRYe38Nov 25, 2020Guru - Experienced User
Did you enable telnet on the RBR and RBS first under IPaddress/debug.htm?
- JoeHagNov 25, 2020Tutor
apparently not. Do you mean something like 192.168.1.1/IPaddress/debug.htm ? or is there something in the software config? The first gets me 404 and I can't find anywhere to enable telnet. Can you tell me where this setting is?
thanks
- CrimpOnNov 25, 2020Guru - Experienced User
telnet is enabled on the Orbi "debug" web page, which is usually at http://orbilogin.net/debug.htm
An alternate URL is http://<IP of router>/debug.htm, which for my Orbi is http://192.168.1.1/debug.htm
"Enable Telnet" is toward the bottom of the page.
