WeirdTechnician
Apr 08, 2019Aspirant
Remove defective RBR50 from account
I had to return a defective RBR50 to Amazon and installed the replacement unit. Now the Orbi App (and the Armor portal) is showing me two devices, the old router and my new device. The new one is o...
Apr 09, 2019Guru - Experienced User
If you select the older system, then select the 3 vertical dots, there should be a remove option there.
Please continue to post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
