Thee
Oct 24, 2021Tutor
Removing Google DNS
Is there a way to remove the Google DNS setting (8.8.8.8) from my switch? I have added my preferred DNS to the list and have deleted the Google DNS from the device however it keeps coming back and p...
- Oct 24, 2021
I messed up on the forum location but I did fix the issue.
you need to place the switch GS716TPP, in DHCP mode and assign an IP address to it via DHCP reservation.
Thanks for the follow up.
Oct 24, 2021Guru - Experienced User
You posted in the orbi forum about a switch but you don't put what switch you have.
If its a smart managed switch, you might do better in the switch forum.
