migsta
Jun 21, 2019Apprentice
Removing Orbi Satellit - How To?
I have 5 satellites - RBR50, RBS50x3, RBS50Y and an RBS20. Looking to remove the RBS20 from the system as the RBS50Y is replacing it. What's the proper way of removing the satellite so the router n...
Jun 21, 2019Guru - Experienced User
I think there is a add/remove feature under advanced settings.
Dust, heat or humidity are not good for any kind of electronic device.
