migsta
Jun 21, 2019Apprentice
Removing Orbi Satellit - How To?
I have 5 satellites - RBR50, RBS50x3, RBS50Y and an RBS20. Looking to remove the RBS20 from the system as the RBS50Y is replacing it. What's the proper way of removing the satellite so the router n...
Jun 21, 2019Guru - Experienced User
With mine, if you go under the attached devices page and the satellite has been powered off, has an option to click remove. You do need to resync afterward if you power the satellite back up. Tried it just now to confirm it works. I took a screen snip of the prior to remove and the after. I'm on the 2.3.1.60 firmware.
