migsta
Jun 21, 2019Apprentice
Removing Orbi Satellit - How To?
I have 5 satellites - RBR50, RBS50x3, RBS50Y and an RBS20. Looking to remove the RBS20 from the system as the RBS50Y is replacing it. What's the proper way of removing the satellite so the router n...
CrimpOn
Jun 21, 2019Guru - Experienced User
migsta wrote:Also, anybody use an RBS50/RBS20 in the garage without any issue? Thinking of putting it there but not if it's going to die from heat/cold, dust, etc.
It depends on the garage. I have had a Nighthawk R7000 in my garage for almost two years. But, this is southern California. NEVER freezes. Only gets up to 105F. If the RBS20 is "surplus" now, what is the harm in trying?
The rbs20 is selling for >$100 on ebay right now. Might be a little harm if it goes bad right away. With that said, I've had an AP in my garage (minnesota) for around that 2 years as well without issues. I do routinely blow it off. I should be using an air canister but its my air compressor I'm using (I know, its horrible) and its still kicking. I've had it shut off when it was -20 degrees but that was the only time and it kicked right back on after a reboot and a little warmer temp.
