migsta
Jun 21, 2019Apprentice
Removing Orbi Satellit - How To?
I have 5 satellites - RBR50, RBS50x3, RBS50Y and an RBS20. Looking to remove the RBS20 from the system as the RBS50Y is replacing it. What's the proper way of removing the satellite so the router n...
CrimpOn
Dec 13, 2019Guru - Experienced User
I thought plemans response was pretty clear. Power off the satellite that you want to remove. Open the Orbi web interface "Attached Devices" page and click on the satellite. There should be an option to "Remove". As long as the satellite is powered up and working, this option does not appear.
VG37
Dec 13, 2019Initiate
I don’t even have the satellites. They were returned to Netgear as defective and replaced. I can’t find anyplace in the app where they can be removed from my network map.
