Berkie
Jan 04, 2018Aspirant
rename SSID / network name
Hello everybody, to avoid extra work with installing a new set of ORBI's. Can I rename the ORBI SSID to my current network name? This because of home automation and heating and other appliances att...
- Jan 04, 2018
Yes, you can rename the SSID just like on any router. Your post confuses me a bit though do you already have an orbi router and are installing another one - the orbi is only meant to function with a single Orbi router and some Orbi satellites with no other routers in the mix.
aaz
Jan 04, 2018Virtuoso
Berkie
i am going to install1 set, but needed to know if the ssid can be renamed.... ( not 2)
