tgarvey's avatar
tgarvey
Tutor
Jul 18, 2018
Renaming RBS 20 satellite
I recently installed an RBK 44 system.  I've been able to rename the RBR 40 router, but when I do the same process on the RBS 20 satellites the new name appears in the Network Map for a few seconds a...
  • DarrenM's avatar
    DarrenM
    Jul 19, 2018
    Are you renaming them from the attached devices page or are you logging into each satellite and renaming them?
    DarrenM
