sandkumar
Jan 23, 2019Tutor
Renaming RBS20 satellite
I have a set up with CBR40 (Router with built-in cable modem) and two RBS20 satellites. I named the satellites during the initial setup. Upon accessing the setup through the Orbi App, it recommended ...
Jan 24, 2019Guru - Experienced User
Have you tried a factory reset on the RBS's and re-add them to see if the name change persists?
sandkumar
Jan 24, 2019Tutor
Will give factory reset a try
- sandkumarJan 24, 2019Tutor
Same behavior after factory reset and goiing theough the setup process again
- FURRYe38Jan 24, 2019Guru - Experienced User
I would file a support ticket here:
https://www.netgear.com/mynetgear/registration/login.aspx
- vkdeltaJan 28, 2019NETGEAR Employee Retired
We will look into it.
- unreliableOrbiFeb 10, 2019Aspirant
I'm having the same issue. I have tried everything. The Orbi system is a piece of crap and the support from Netgear is appalling. I have never had so many issues with networking gear.
- FURRYe38Feb 11, 2019Guru - Experienced User
Other than renaming the RBS, the CBK has worked well for me. ZERO issues.
Is the CBK40 working for you other than re-naming the satellite? Is it that important?
