sandkumar
Jan 23, 2019Tutor
Renaming RBS20 satellite
I have a set up with CBR40 (Router with built-in cable modem) and two RBS20 satellites. I named the satellites during the initial setup. Upon accessing the setup through the Orbi App, it recommended ...
sandkumar
Jan 24, 2019Tutor
Will give factory reset a try
sandkumar
Jan 24, 2019Tutor
Same behavior after factory reset and goiing theough the setup process again
- FURRYe38Jan 24, 2019Guru - Experienced User
I would file a support ticket here:
https://www.netgear.com/mynetgear/registration/login.aspx
- vkdeltaJan 28, 2019NETGEAR Employee Retired
We will look into it.
- unreliableOrbiFeb 10, 2019Aspirant
I'm having the same issue. I have tried everything. The Orbi system is a piece of crap and the support from Netgear is appalling. I have never had so many issues with networking gear.
- FURRYe38Feb 11, 2019Guru - Experienced User
Other than renaming the RBS, the CBK has worked well for me. ZERO issues.
Is the CBK40 working for you other than re-naming the satellite? Is it that important?
- unreliableOrbiFeb 11, 2019Aspirant
I agree, it's not important. This is incredibly low on the priority list of the multiple issues I'm experiencing with my router and satellites, but this also illustrates how buggy the HW and SW are on the Orbi system.
I spent 2 hours on the phone with technical support yesterday and have not made any progress. It's been a very tiring trial and error process where one customer service rep does not pass the information to the next. I'm constantly having to start everything all over again. Yesterday they told me they are going to send me a new router, today is not a new router, it's a new satellite. Tech support has no clue what they are doing. Netgear should be paying customers for their time testing this, not the way around!!!
