iOSBoss
Feb 11, 2020Aspirant
Repeated Orbi Wifi drops
Using the RBR20 router with one RBS20 satellite Router Firmware Version V2.3.5.36 <3,000 ft single story home Satellite to base station about 30 ft (some normal frame walls between) Distance to satell...
Feb 12, 2020Guru - Experienced User
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
iOSBoss wrote:
Using the RBR20 router with one RBS20 satellite Router Firmware Version V2.3.5.36 <3,000 ft single story home Satellite to base station about 30 ft (some normal frame walls between) Distance to satellite - <3 ft Very stable internet connection via Arris SB6183 cable modem Distance to nearest neighbor is at least 200 ft. My Wifi signal strength is 4/4 bars on both main and guest network. I can max two other Wifi networks with 2 bars or less of signal. As has been reported by others, the Wifi simply hangs multiple times an hour. It's a brief pause - usually around 30 seconds +/- before everything resumes. I have extensively played around with config changes including: - Manually setting 2.4 and 5GHz channel (current setting is 04 and 36 respectively) - Enabled/disabled WMM (Wi-Fi multimedia) settings (currently disabled) - Enabled/disabled Daisy-Chain Topology (currently disabled) - Enabled/disabled Implicit BEAMFORMING (currently enabled) - Enabled/disabled MU-MIMO (currently disabled) - Enabled/disabled Fast Roaming (currently disabled) There are too many permutations of these to try them all, but the problem persists. Any other suggestions? Thanks in advance!
