iOSBoss
Feb 11, 2020Aspirant
Repeated Orbi Wifi drops
Using the RBR20 router with one RBS20 satellite Router Firmware Version V2.3.5.36 <3,000 ft single story home Satellite to base station about 30 ft (some normal frame walls between) Distance to satell...
iOSBoss
Feb 12, 2020Aspirant
CrimpOn The behavior is simply observed as a "pause" in any web access. Web access is suspened / unresponsive for all synchronous Wifi connected devices (simultaneously).
Our home security system, which is hard wired to the base station (which in turn is also hard wired to the cable modem) is not reporting any internet disconnects, however all Wifi connected devices lose access, hence it stands to reason that the disruption is in the Wifi network.
| Lease Obtained | 1 Days, 0 Hours, 0 Minutes |
| Lease Expires | 0 Days, 23 Hours, 1 Minutes |
iOSBoss
FURRYe38 I have not tried a factory reset and setup - I would hope that could be avoided. It's a potentially painful procedure to ensure some 50+ internet connected devices and the daisy chain ecosystem (e.g. security system, and sensors) all reconnect properly. I guess I can try it but view it as a last resort.
