iOSBoss
Feb 11, 2020Aspirant
Repeated Orbi Wifi drops
Using the RBR20 router with one RBS20 satellite Router Firmware Version V2.3.5.36 <3,000 ft single story home Satellite to base station about 30 ft (some normal frame walls between) Distance to satell...
iOSBoss
Feb 12, 2020Aspirant
Yes, all Wifi devices. For example I have an Alexa in the room with and connected to the Orbi base which often streams music which will stop streaming at the same time my laptop browser(s) become unresponsive in my office which is where the satellite is located.
I cannot easily verify if my iOT devices (thermostats, irrigation controllers, cameras, etc.) lose connectivity since they don't time out that fast, but I assume so. As mentioned, my alarm system, which is hardwired, seems to stay connected (I'm working to verify this).
I have pretty much every device know to man that runs on Windows, MacOS, Fire OS, and iOS. Desktops, laptops, tablets, smartphones.
CrimpOn
Feb 12, 2020Guru - Experienced User
iOSBoss wrote:I have pretty much every device know to man that runs on Windows, MacOS, Fire OS, and iOS. Desktops, laptops, tablets, smartphones.
It might be useful to confim that the issue is on the "Orbi side" and not the "ISP side." For example, on a Windows computer wired to the Orbi router, open a "Dos Window" (CMD: prompt) and begin to ping someplace. I suggest Google DNS (8.8.8.8). This will send one ICMP request (ping) per second. (The command is: ping 8.8.8.8) When you hear the music stop, look at the computer. Is it still "pinging away"? If so, the internet connection appears to be good, and the problem is on the "Orbi side."
Another tool is to check the CPU activity on the Orbi. On the Orbi debug page (http://orbilogin.net/debug.hem), check the box "Enable Telnet". Then, open a telnet program on a computer that is wired to the Orbi (could be the same one doing ping). Log in using the admin credentials, "admin" and password, and run the "System Activity Report", as follows:
sar 2 2000 (This means every 2 seconds for 2,000 times)
When the music stops, look at the telnet screen. Has the CPU spiked?
- CrimpOnFeb 12, 2020Guru - Experienced User
Oh, my. Did we remember to ask the usual question, "Do you have Disney Circle or Bitdefender Armor activated?"
- iOSBossFeb 12, 2020Aspirant
CrimpOn Negative Ghostrider - no parental controls or incremental security here. I've set up a PC for monitoring the connection at the base. Thanks for the help.
"2-3 times an hour". The music should have stopped by now?
Or, is this like Schrödinger's Cat? The act of observing the internet state keeps it alive?
