iOSBoss
Feb 11, 2020Aspirant
Repeated Orbi Wifi drops
Using the RBR20 router with one RBS20 satellite Router Firmware Version V2.3.5.36 <3,000 ft single story home Satellite to base station about 30 ft (some normal frame walls between) Distance to satell...
iOSBoss
Feb 12, 2020Aspirant
CrimpOn Negative Ghostrider - no parental controls or incremental security here. I've set up a PC for monitoring the connection at the base. Thanks for the help.
CrimpOn
Feb 12, 2020Guru - Experienced User
"2-3 times an hour". The music should have stopped by now?
Or, is this like Schrödinger's Cat? The act of observing the internet state keeps it alive?
