pjewett's avatar
pjewett
Guide
Jun 16, 2022
Replace RBR20?
Hi All,
I've had an Orbi RBR20 with 3 satellites (including outdoor model) for a few years now and have been happy enough. I've always had no choice it seems but to run it in AP Mode due to incompatibility (separate streams for cable and internet) with Fios setup.
However, now that I'm working from home I have my work laptop on my network and I want it isolated from my home network. Guest Network while in AP mode still leaves my network visible.
Assuming the above can't be remedied what Orbi products are actually fully compatible with Fios so I don't have to use it in AP mode....or what model will allow me to create an isolated network for work hardware and guests?
Thanks in advance.
  • plemans's avatar
    You'd want something that supports vlans. And most consumer models don't. Business models do.
    What issue are you running into with putting the work computer on the guest network? Just trying to figure out whats going on and what you're attempting to achieve.
    • pjewett's avatar
      pjewett
      Guide
      Hi, thanks for the reply. Well, I'm trying to (have tried) to accomplish two things. The way I see it they are connected.
      Equipment
      Verizon Quantum Gateway Router (Fios)
      Orbi (RBR20)
      (2) Orbit Satelites (RBW30)
      (1) Outdoor Orbit Satelite (RBS50Y)
      Current Setup
      Wifi radios turned OFF on Quantum Router
      Orbit in AP mode.
      Goal 1 (Security)
      I want my home network as secure as possible with my company issued laptop now reguarly on my wireless network. I've confirmed that my Orbi in AP mode allows guests to see each other and my local network. This is checked and greyed out in Guest Network settings of my Orbi. I and my wife's work laptop are on this guest network and we see each other and other local services/machines. We have our work laptops set to Public and they still appear on the guest network. Bottom line- I don't want my employers accessing any of my local home network.
      Goal 2 (Use Orbi in Router mode)
      If I can user my Orbi in Router mode I'm thinking I can setup a truly isolated guest network and I'd like to be able to use it's other features. We also use STB's for TV service so I've been reading up on Moca adapters but haven't been able to confirm what my scenario would be (ie., do I need WAN or LAN adapters, etc.).
      Thanks very much for your time.
