Jazijia
Mar 02, 2020Aspirant
Replacement Adapter - Orbi Satellite
Hi all I have an Orbi RBR20 system and the satellites are RBS20 model. One of the satellites power adapter has malfunctioned and is out of warranty, so I have to buy a replacement. The model ...
Mar 02, 2020Guru - Experienced User
Find one on Amazon that matched the putout voltage and amps as the original one.
- JazijiaMar 02, 2020AspirantThat's the easy part and I got that. I need to know the size of connector pin that goes in the satellite.
- FURRYe38Mar 02, 2020Guru - Experienced User
Might look at the spec sheets to see. Most of the pin connectors are all the same and general size. Even if you do a search on replacement power adapters, the pin connector should be the same. Can ask the seller to confirm this as well.
- JazijiaMar 02, 2020AspirantI couldn't locate the spec sheet and also called up Netgear but they had no idea.
