Jazijia
Mar 02, 2020Aspirant
Replacement Adapter - Orbi Satellite
Hi all I have an Orbi RBR20 system and the satellites are RBS20 model. One of the satellites power adapter has malfunctioned and is out of warranty, so I have to buy a replacement. The model ...
Webheadjunky
Apr 07, 2020Aspirant
Hi dont want to hijack this thread. I am in UK. I have purchased used RBK50 set and was looking forward to setting it up. Idiot that I am, I cut the wire on one of the adapters when removing bubble wrap! Could you recommend a replacement please? There is one on Amazon that appears to be unavailable. Grateful for your advice.
Apr 07, 2020Guru - Experienced User
Contact NG support.
https://www.netgear.com/support/#
- WebheadjunkyApr 07, 2020AspirantThanks. I could not see an option to raise a ticket with support? Any tips?
